Issue/Bug: StaticLogic Error when restarting VC
NFC
Hi to all,
[I work in ABB and use RS almost everyday, but I don't know where and how to post a bug report. What's the right place?]
If you have some I/O connection in station logic between a SmartComponent and a VC, when you restart the VC, you'll get an Unhandled Exception.
This will prevent station logics to work properly until RS is restarted.
RobotStudio .NET exception: Exception from HRESULT: 0xC0040401
Base exception: COMException
at Interop.LgVCHelper.ILgVCHelper.GetIOSignalInfo(String signal, Boolean& blocked, Boolean& isDigital, IOSignalValue& logical, IOSignalValue& physical)
at RobotStudio.Services.Controller.ControllerService.GetIOSignalInfo(RsIrc5Controller ctrl, String signal, Boolean& isBlocked, Boolean& isDigital, Object& logicalValue, Object& physicalValue)
at RobotStudio.Services.Simulation.EventTableLogic.GetIOValue(ProjectObject obj, String signal, Object& val)
at RobotStudio.Services.Simulation.EventTableLogic.GetFiredIOs()
at RobotStudio.Services.Simulation.EventTableLogic.AfterTick(UInt32 simTime)
at RobotStudio.Services.Simulation.EventTableLogic._timer_Tick(Object sender, EventArgs e)
Forgot to mention RS 5.14... sorry0
UP0
This will be fixed in 5.14.01.
regards,
Johannes.
Johannes Weiman
Hi Nils,Defects should be reported in the PDD database. For access, add a request in C2.Best regards,
Anders Jahnberg
ABB Robotics0
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
