?How to set up virtual Group Output/Input signal?
CryI added virtual in unit type and defined unit with virtual bus and virtual type as well.
After I added group out/input they cant be seen in I/O simulator.
Cry
does anyone know why is that?
I set all trust levels to required(0)
Access levels = all
Default values = 0
unit mapping = 0-7
  • Klaus
    Klaus ✭✭
    I had same problem but a work around is to add a single signal in the group then the group signal can bee set
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Hey I'm having the same problem, except it doesn't show up even after I've created the signals
    Please help!
  • Klaus
    Klaus ✭✭
    send me a backup of the controller to ks@cadalysator.dk and i will try to help you
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Hey Klaus,
    I managed to get it working!
    Thanks for the offer to help :)
  • Klaus
    Klaus ✭✭
    How???
    Could be usefull for others to know your solution
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • I actually have no idea...
    I'm pretty sure it was just the computer I was using at the time, because it worked fine on my laptop and then when I tried to use the other computer, it didn't work properly
    I can send you the file I used :S
  • Klaus
    Klaus ✭✭
    no it was only if it was an error you have found
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • I figured out my case.
    I create Unit and Unit Type in I/O configuration with same name.
    that is allowed by Robotstudio, but illegal.
    When you do that, not only does it make you cannot see the signals you created in the unit you've created, but also makes Robotstudio station clash after you reboot the program.
    My tutor said, Robotstudio has a lot of bugs.
    Here is my configuration set up, share with you guys.
    Create unit type as virtual
    Create Bus as virtual
    Create unit and pick the type and the bus you've just created.
    then create signals with the unit you've created.
    then you can actually see signals in the I/O simulator.
    dont forget to map you signal in different digit,
    if you map signals into a same digit, if you make a change to 1 signal.
    you make changes to all signals.
    • Open in Google Docs Viewer
    • Open link in new tab
    • Open link in new window
    • Open link in new incognito window
    • Download file
    • Copy link address
    • Edit PDF File on PDFescape.com
    seanfan842011-05-21 13:17:56
