?How to set up virtual Group Output/Input signal?
After I added group out/input they cant be seen in I/O simulator.
does anyone know why is that?
I set all trust levels to required(0)
Access levels = all
Default values = 0
unit mapping = 0-7
I had same problem but a work around is to add a single signal in the group then the group signal can bee setBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hey I'm having the same problem, except it doesn't show up even after I've created the signalsPlease help!0
send me a backup of the controller to ks@cadalysator.dk and i will try to help you
Best Regards
Klaus Soenderhegn
Hey Klaus,
I managed to get it working!
Thanks for the offer to help
How???Could be usefull for others to know your solutionBest Regards
Klaus Soenderhegn
I actually have no idea...
I'm pretty sure it was just the computer I was using at the time, because it worked fine on my laptop and then when I tried to use the other computer, it didn't work properly
I can send you the file I used :S
no it was only if it was an error you have foundBest Regards
Klaus Soenderhegn
I figured out my case.I create Unit and Unit Type in I/O configuration with same name.that is allowed by Robotstudio, but illegal.When you do that, not only does it make you cannot see the signals you created in the unit you've created, but also makes Robotstudio station clash after you reboot the program.My tutor said, Robotstudio has a lot of bugs.Here is my configuration set up, share with you guys.Create unit type as virtualCreate Bus as virtualCreate unit and pick the type and the bus you've just created.then create signals with the unit you've created.then you can actually see signals in the I/O simulator.dont forget to map you signal in different digit,if you map signals into a same digit, if you make a change to 1 signal.you make changes to all signals.seanfan842011-05-21 13:17:560
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
