Slow cursor in Online/Offline editor
Klaus
Hi.
After Upgrading to RS 5.14 the Rapid editor in Both on/Off line is very slow.
When i move my cursor it goes 10 times slower as in RS 5.13.
How come?????
Have you add some syntax check or what.
PS it is the text cursor not mouse
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
HalloAm i the only one to face this problem!!!!!!!!!!!!!!!Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Try unloading any VSTA add-ins.Henrik Berlin
Hej HenrikI have no VSTA add-insBest Regards
Klaus Soenderhegn
Try to run the attached script. It will re-register some components of the RobotCommunicationRuntime. As an effect, the performance will revert to normal for affected installations. The script will not cause any harm to installations that did not have the problem with the component registration.webwiz/772/Reg_ComServer_NetScan.zip(The script is also available on the RobotWare 5.14 DVD, in the Utility folder).
The scrip do not work.Wrong path.I'm running Win 7 64 bitBest Regards
Klaus Soenderhegn
Hi Klaus,We will investigate this.Best regards,
Hi,any solutions? I have the same performance problems and the script doesnt work!Best regards.ZM2011-06-22 11:59:330
This performance issue will be solved in the upcoming service release.The new release, RobotStudio 5.14.01 will be available within short.Best regards,Göran Holmqvist
RobotStudio 5.14.01 is now available for download.Best regards,
ABB Robotics0
- 336 IRC5
- 67 OmniCore
- 830 RAPID Programming
- 13 AppStudio
