cant delete workobject
wolfino
I have the new RS 5.14. I needed to delete thew workobject i have created but it is not possible it says "failed to delete objects". I have tried a couple more times so now iam having four new workobject but non of them possible to delete. is it a known bug or something?
Please get in touch with your local ABB Service representative that can forward your problem to our tech support.Henrik Berlin
Did you ever get an answer to why you couldn't delete a wobj? I'm having the same issue. Can you give any advise?phil0
I talked with tech support but they didn't help too much. I finally stumbled on the solution. I had to delete any path that used robtargets in the Wobj's. Sometimes I even had to delete all the paths, even though the targets in some of the paths did not reference the Wobj's I was trying to delete. Didn't work like this in previous versions. Hope they fix this one, it's a pain.phil0
- 365 IRC5
- 84 OmniCore
