RECORD across different tasks
apox
Hi, how to i define a RECORD which i can access in different tasks?
If not possible, is there a workaround?
Regards.
Regards.
Declare the record in a module in each task.Thomas H. Johnston
PACs Application Engineer0 -
Declare As PERS and only Init one off them with valuesBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Create a module and set to multi-task, after declare what you need it.Tip: Look swuser.sys in spotware use VirtualKey in robotstudio.0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
