Production Manager fo Milling??
 Hi to all,
   I'd like to know if is it possible to create a Production Manager like in a weld cell but for a milling cell, using ScreenMaker.
  If the answer is yes, I'd like to know how.
 Best Regards
  • hello:
    ScreenMaker 5.14 comes with pre-defined templates basic, standard, and extended. You can use them to create your screens quickly: in addition to using Production Monitor
    Best Regards, Srini
  • Hello:
    Production Manager (812-1) can be obtained as an option for any application. You need to customize it per the Application Manual.
    Best Regards, Jim Proulx
