RobotStudio 5.14 hangs when?...
RobotStudio hangs when when attempting to restart the controller from the FlexPendants prompt message after edditingn an I/O signal.
This will happen when you get the FlexPendant dialogue that suggests the you need to close the flexpendant.
I can reproduce the problem when Re-editing a group output signal in I/O parameters.
Did not see this behaviour on 5.13, this happens on both XP and Win7.
Cry
  • OK... I may have figured this out...
    The 'FlexPendant Restart Needed' message appears if the I/O simulator is open within studio.
    At the point you close the pendant, studio hangs... and you will need to use Task Manager to End Studio.
    Shocked
  • Hi sturner,
    Please report this kind of problems in our internal ABB tools.
    ABB Robotics
