Help !Command Bar no event action
lister
in ScreenMaker
lister2011-06-22 04:07:37
Please help to check why the command bar menuitem no event action?
I make a command bar and a button,why the command bart menuitem no action?
Thanks /Lister
Hello,Events should be defined for each menuitem that gets created for CommandBar.To add events to the menu item,- In the Properties window, select the menu item from the drop-down list.
- Click Events icon and double-click to open the Events Panel.
- Click Add Action to add an action/event to the menu item.
Kindly lets us know if you need more information.Thanks0 - In the Properties window, select the menu item from the drop-down list.
