Create offline system from online
I have a IRB140 robot with a program, points, tools, etc... created.
What i want now is to copy all of that to my pc, and make changes, simulation offline, etc.
I also want to be able to send the changes back to the real robot.
How can i copy an real robot to the virtual robot?
Ricardo Gomes
http://ricardogomes.eu
HiIf you connect to real robot with your RobotStudio, you can find a Go Offline -button from Online tab. That will create a virtual system from your real robot. Please see more detailed information about Go Offline from RobotStudio Help.-Osku0
Hi.I had problems with the "Go offline" function.My advice is to dreate a backup of the real controller and then create system from backup.That works and takes about 5 min.Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 336 IRC5
- 67 OmniCore
- 830 RAPID Programming
- 13 AppStudio
