Slow cursor in Online/Offline editor
Hi.
After Upgrading to RS 5.14 the Rapid editor in Both on/Off line is very slow.
When i move my cursor it goes 10 times slower as in RS 5.13.
How come?????
Have you add some syntax check or what.
PS it is the text cursor not mouse
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Klaus
    Klaus ✭✭
    Hallo
    Am i the only one to face this problem!!!!!!!!!!!!!!!
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Try unloading any VSTA add-ins.
    ABB
  • Klaus
    Klaus ✭✭
    Hej Henrik
    I have no VSTA add-ins Wink
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Try to run the attached script. It will re-register some components of the RobotCommunicationRuntime. As an effect, the performance will revert to normal for affected installations. The script will not cause any harm to installations that did not have the problem with the component registration.webwiz/772/Reg_ComServer_NetScan.zip(The script is also available on the RobotWare 5.14 DVD, in the Utility folder).
    ABB
  • Klaus
    Klaus ✭✭
    The scrip do not work.
    Wrong path.
    I'm running Win 7 64 bit
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Hi Klaus,
    We will investigate this.
    ABB Robotics
  • Hi,
    any solutions? I have the same performance problems and the script doesnt work!
    Best regards.
    ZM2011-06-22 11:59:33
  • This performance issue will be solved in the upcoming service release.
    The new release, RobotStudio 5.14.01 will be available within short.
    Göran Holmqvist
    ABB
  • RobotStudio 5.14.01 is now available for download.
    ABB Robotics
