motion supervision option
wayneisa
Hi all,
Is there a way to check if motion supervision option is installed? Does it come with ever robot or is it a extra cost?
Thx
Hi,You can check the installed options via the FlexPendent, under the System Info topic on the main menu (right hand column)->system properties->Options.Basic motion supervision comes with every robot, but the option gives you more features.Hope this helps.Graeme0
GraemeThanks for the helpIt looks like it is not installed.Maybe this is why I can't make changes to the values in the motion supervision screen.0
