.Net SDK ?
labu
The installation of RS5 tells about an SDK .Net.
I can not find it and the SDK help is disabled, is it a future feature?
Best Regards,
Laurent Businaro
Best Regards,
Laurent Businaro
Hi Laurent
In the folder 'C:Program FilesABB Industrial ITRobotics ITRobotStudioSDK' you can find a couple of public assemblies as well as a help file describing the assemblies.
Right now it's only possible to develop Addins for RS and you do that by using VisualStudio.NET unfortanally there is no documentation or templates yet how to do this.
Probably in near future there will be a editor like the VBA editor in RobotStudio for S4 and then there will be documentation how to use the RS API.
Per Svensson
Company Specialist
ABB Automation Technology Products0
This discussion has been closed.
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
