Obj reference
Hello !
I have just started to work with robotstudio, so i have a question about obj reference fault.
After i have saved the work, and maybe next day i will open it again, i will have a fault that
appears. Obj reference not set to an instance of an object?  and i cant do anything? i need to start overCry
/Bobban
  • Hi,
    If you get this error message for all your stations, I recommend that you reinstall RobotStudio to see if that solves the problem. If you still have problem after the reinstall, please contact your local ABB office for support.
    ABB Robotics
