Smart Component
Julito_
Hi, I am new wth robotstudio.
I have got a problem when I setup a SC. When I setup my joint pose and I put a value to duration my item isnot working well. But when I let my setup to 0 is working OK. I receive my executed signal, when I setup 2 s I have got oly my executing and anything else...
This SC is to setup a open and close gripper.
Could you help me please.
Thank you.
Tout est au mieux dans le meilleur des mondes possibles.
Any idea??I still having troubles. When I put 2 seconds in my duration parameter my SC is not working correctly. In my mecanism I setup my st transitions times but it isn't working too when I run my simulation...Thanks.Tout est au mieux dans le meilleur des mondes possibles.0
Are you running the simulation when you try your Smart Component?Best regards,
Yes Anders, I am running my simulation.Tout est au mieux dans le meilleur des mondes possibles.0
If you mail me a Pack and Go with the Smart Component I will take a look at it.Best regards,
Find something wrong????Tout est au mieux dans le meilleur des mondes possibles.0
Your "SC_Gripper" Smart Component was not part of the simulation, that's why it not was working.I have mailed you a new Pack and Go.Best regards,
Thanks a lot is working great.Tout est au mieux dans le meilleur des mondes possibles.0
