Paint Power Pac and Conveyor Tracking [Painting PowerPac]
Hello,Try to first Process the workpiece to divide it and then attach to the Conveyor.Reason is that after processing a workpiece from Painting Powerpac, the part is divided and saved as a Graphic Component Group (GCG).Hope this helps,sudarshan0
Thank you, that worked. But I am still having a lot of problems with my part getting divided and then trying to use Auto Stroke. I will start another thread with that problem.
