Process time machine
Julito_
I wish to simulate a process time machine.
I closed or clamped my machine and after 40 seconds I unclamped or opened and my machine is ready to unload.
All of this must be independent of my robot.
Is it a way to simulate this in robotstudio.
Thanks I ppreciate your help
Tout est au mieux dans le meilleur des mondes possibles.
Hi.
Yes there is.make your machine as a mechanical device.Add it to a smart componentsIn your (SC) you copy a part in the machine to unloadyou create a task in your robot to controll the running of your SC(Add option multitask to your robot)This simulation is made using some SC and all off the controlled with rapid code in multitask of the robot controllerBest Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Thanks a lot.Great0
- 336 IRC5
- 67 OmniCore
- 830 RAPID Programming
- 13 AppStudio
