Failed To Create System
Paddy C
Hello, After installing RS 14 to my new laptop (running windows 7), after being able to create systems using the installed media pools, RS now fails to create systems. The system builder create system starts ok, but then asks for the location of the media pools. After selecting the folder where they are located, RS simply states failed tocreate system. I have uninstalled both RS and the robotware, re-installed them, but the same problem occurs. Any ideas?
Have you tried to create systems with "System From Layout" instead of using "system builder"?Best regards,
Hi Anders, Thanks for the reply. Tried this just now, but this time robot studio states that the mediapool directory is invalid. Moved the directory out of the program files(x86) into the user directory, but still the same fault:- invalid directory
Hi to all.I have the same problem.I have tried uninstalled, cleaning registry, re-install and still the same problem.The mediapool listbox is empty and I have an error when trying to load a system.Any idea ?CM0
Hi all,Please report this problem to your local ABB office so we get a formal report of the problem.Add a "RobotStudioReport" from the "RobotStudio Support Tool" with the report.Best regards,
Hi all, Have managed to get it working by installing Robot Studio 13. After doing this, the media pools became visible and RS14 works ok. Will try uninstalling RS13 to make sure this was the fix, but seems strange that it works ok after doing the install.
HI All,Did you installed the release RB13 after installing the RB14 ?When I have installed the RB14, the RB13 have been automatically uninstalled.CM0
Your trick does not work for me ...0
Hi CM, Sorry to hear that it didnt work for you. I also uninstalled net framework and all updates for it, then when i installed RS13, it installed the net framework again. I then let windows 7 update the framework stuff, and it still works. Might be worth a try.
Will try this and let you know ...0
After removind all .net framework, xml package and c++ runtime, I have reinstall both RS13 and RS14 and it still doesnot work ... Sniff0
Any idea ?0
If this is still a problem, try the solution described in http://forums.robotstudio.com/forum_posts.asp?TID=5930.Henrik Berlin
Hi, when I try to create my system form layout it appears a "fatal error" with no solutions provided. What can I do to fix this problem.ThanksPedro Silva0 -
Hi Pedro,Thank you for using the forum. If you have any questions or comments related to an existing topic you are welcome to add a post to it, but if your question is not directly related to any existing topic it is preferrable to start a new topic.In any case, I'll try to help you. What is in your station when you do "System From Layout"? Are you able to create a create a standard robot system (File->New->Station with Robot Controller->IRB120_3kg_etc..)?Henrik Berlin
Hi, the system that I'm trying to create has a robot 1600 and a positioner IRB250K.If I try to create a system from template or without a positioner I have no problem, that's why I need help.ThanksPedro Silva0
Hi Henrik, I've already overcome those problems, I get the new robotstudio version 5.14. Now I've no problem creating the system that I need.Thank you for your time.Kind regards,PedroPedro Silva0
- 336 IRC5
- 67 OmniCore
- 830 RAPID Programming
- 13 AppStudio
