Reading Modul names with RAB
Hello everybody,
i would like to read out all the modules(as string) of the Robotcontroller and would like to put them listed in a combobox!
Anyone an idea how i can solve this problem
I tried some things out (in VB) but nothing really work by now.
tRob1 = ctrl.Rapid.GetTask("T_ROB1")
RSCol = tRob1.SearchRapidSymbol(SProp, "Module", String.Empty)
Is "Module" correct? Or must it be "mod" or "modul"
And after that how can i read out "RSCol"
Maybe this is the complete wrong way, i don't know
Anyone an idea?
Cheers "7"
7seven2011-08-05 11:31:12
  • This is the code i use in VS2008 VB
    Dim TaskName As String = "T_ROB1"
    Dim modulantal As Integer = robotController1.Rapid.GetTask(TaskName).GetModules.Count
    ComboBoxModules.Items.Clear()
    For i = 0 To modulantal - 1
     Dim modul As RapidDomain.Module = robotController1.Rapid.GetTask(TaskName).GetModules(i)
    ComboBoxModules.Items.Add(modul.Name)
    Next
    ComboBoxModules.SelectedIndex = 0
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • [QUOTE=Klaus]
    Next
    [/QUOTE]
    Thanks a lot Klaus, this one really help me out Clap
    But i had to change one thing!
    I had to replace GetModules.Count with GetModules.Length
    I don't know why. Anway, it works Tongue
    Once again thank you for the code.
    Cheers "7"
  • super that it works
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
