cant delete workobject
I have the new RS 5.14. I needed to delete thew workobject i have created but it is not possible it says "failed to delete objects". I have tried a couple more times so now iam having four new workobject but non of them possible to delete. is it a known bug or something?
  • Please get in touch with your local ABB Service representative that can forward your problem to our tech support.
    ABB
  • Did you ever get an answer to why you couldn't delete a wobj?  I'm having the same issue.  Can you give any advise?
    phil
  • I talked with tech support but they didn't help too much.  I finally stumbled on the solution.  I had to delete any path that used robtargets in the Wobj's.  Sometimes I even had to delete all the paths, even though the targets in some of the paths did not reference the Wobj's I was trying to delete.  Didn't work like this in previous versions.  Hope they fix this one, it's a pain.
    phil
