Setup network boot S4c 3.0
ZarooS
hi, i'm trying to conect my IRB 6400 M98, with OS S4C 3.2 to a PC for store programs.
they have in the A71 a Network I/O computer DSQC336 with Ethernet connector.
i try several nfs servers, but it still give me a protocol nfs0 error and can't mount a drive in the robot.
A?have anyone idea of where i can found the Setup network boot S4c 3.0 (3HAB2392-2) disk or other program to connect my robots to a PC?
thanks in advance.
thanks in advance.
i continue to search and found that ABB upgrade this software to one compatible with Windows XP called "Ethernet Utilities".
A?somebody knows where i can obtain a copy of this software?
You could found it via Solutions Bank:
Document Title: RobotWare Setup network boot NT
ABB Document Number: 3HAC2699-1/01
http://search.abb.com/library/
http://solutionsbank.abb.com/
I have never tested it. Would be better upload the BW by TPFTd daemon, but i dont't know how to configure FTP daemom or if possible put all the BW files in one directory.RobotWare_Setup_network_boot_NT_2699-1.zip
Olda,
Thanks for this wonderful info. I was looking for this and now I found like winning a trasure..:P You made all the possibilities that I can make use and install this in my PC. Thanks again!
s4online utilty BW 3.0 and higher http://library.abb.com/global/scot/scot241.nsf/veritydisplay/c069a90761a40426c12579e30048fa06/$file/s4online_2.0.2_cd_image.exe
only if option RAP Serial Link or FactoryWare Interface
S4Online
about RobotWare Setup network boot NT: will ... only made key.id/media.id ...
-id ABB_BOOTSYS1 -key "-path ""/tftp/s4boot/programs/3hac2700-2/disc.1/abb_boot.sys"" -volume -1"
you need configured bootp daemon on server not dhcp with appropriate MAC address.
- 344 IRC5
- 70 OmniCore
- 840 RAPID Programming
- 19 AppStudio
