Mechanism Transition Times
I am sorry if this question sounds stupid!
I am trying to build a mechanism device. All the links and joints are well defined.
The only problem is the transition times seem not effected at all.
I am using the trail version, is that the reason.  Can anyone tell me what I missed.
Tim
  • Hi Tim,
    Transition times are only used when you run a simulation. But instead of using transition times, I recommend you to create a Smart Component to control your mechanism.
    The trial version has nothing to do with this, it has full functionality in 30 days.
    ABB Robotics
  • Hi
    I also had a mechanism that jumped from one position to the other. I also had the problem with Smart Components. Just when I made a video it took the correct transmission time. After some time also in normal play mode the transmission time was correct.
    Best regards
    Marcel
  • Hi Anders,
    It works perfect in SC and simulation.
    Thanks for your help,
    Tim
