Condition to open screen - ScreenMaker
Hello colleagues
I need to open determined screen based on application variable value on ScreenMaker 5.14.
It should be something like this:
If ApplicationVariable = "A" then OpenScreen 1
If ApplicationVariable = "B" then OpenScreen 2
I get the value of application variable during RAPID execution
I tried to use "Conditional Trigger" control, but with no success
Maybe I donA't know how to use it on the right way.
Can somebody help me with this case?
Thanks in advance !!
  • Hello,
    Conditional Trigger gets triggered if the condition is satisfied. I have tried to create a document describing a simple example on using conditional trigger which has a similar scenario.
    Hope this helps.
    Thanks.
  • Hello !
    Really thanks for your help
    It worked in my application
    Just a question to clarify ...
    What does "LHS" and "RHS" means ?
    I would like to know what the acronym means ...
    Thanks once again !!
  • Hello,
    Thanks for your inputs, here LHS stands for Left Hand Side and RHS stands for Right hand side.
    If we have an expression like A EQUALS B or A GREATER B
    'A' would be the left hand side value to be compared with the Right hand side value 'B'.
    Hope this makes it a little clear.
  • Hello
    Thanks for answer
    Easier knowing the concept !
    Thanks once again !
  • Nice post!
    I'll try to se the attachment in Abhishek reply.
    Have a nice day :DThumbs Up
    Manuel Perez Lopez
  • thanks abhishek you are right..
