Condition to open screen - ScreenMaker
Rafael
in ScreenMaker
Hello colleagues
I need to open determined screen based on application variable value on ScreenMaker 5.14.
It should be something like this:
If ApplicationVariable = "A" then OpenScreen 1
If ApplicationVariable = "B" then OpenScreen 2
I get the value of application variable during RAPID execution
I tried to use "Conditional Trigger" control, but with no success
Maybe I donA't know how to use it on the right way.
Can somebody help me with this case?
Thanks in advance !!
Hello,Conditional Trigger gets triggered if the condition is satisfied. I have tried to create a document describing a simple example on using conditional trigger which has a similar scenario.Hope this helps.Thanks.0 -
Hello !
Really thanks for your help
It worked in my application
Just a question to clarify ...
What does "LHS" and "RHS" means ?
I would like to know what the acronym means ...
Thanks once again !!0 -
Hello,Thanks for your inputs, here LHS stands for Left Hand Side and RHS stands for Right hand side.If we have an expression like A EQUALS B or A GREATER B'A' would be the left hand side value to be compared with the Right hand side value 'B'.Hope this makes it a little clear.Thanks0 -
Hello
Thanks for answer
Easier knowing the concept !
Thanks once again !0 -
Nice post!
I'll try to se the attachment in Abhishek reply.
Have a nice day
Manuel Perez Lopez0 -
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
