Database [WebWare Server]
Hello Ronny,
Probably the simplest method would be as follows (this applies to a data table):
1. Display the desired report with the WebWare client.
2. Select all of the data in the table and do a "ctrl+C", i.e. copy.
3. Paste this data into a Word document, save the page as html.
4. Open Excel, select Data>Import Data then browse to the html file.
5. Follow the steps for importing data and format as necessary.
I did this in Office 2003, I expect Office 2000 and later should work similarly.
Russell Drown0
- 367 IRC5
