Error using pulsetime
Klaus
in ScreenMaker
I use SM 5.14.1032
I get this error when i add time in millisec on a pulse event in a button.ScreenMaker -> Build Error -> Screen d:Screenmaker projektsGUI mpMainScreen.cs - Line 371 : Argument 1: cannot convert from 'double' to 'int' 27-09-2011 14:06:20 ScreenMaker .
If i enter pulsetime in 200 i get this error but if i use an application variable with same value it works.
The C# code that makes the error is this:
((ABB.Robotics.Controllers.IOSystemDomain.DigitalSignal)(ABB.Robotics.ScreenMaker.Windows.Forms.DataManager.GetSignal(this, "IOSYSTEM/SIGNALS/DO_PlacePosReady"))).Pulse(200D);
.Pulse(200D); this must be wrong
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hello Klaus,The issue mentioned has been fixed in 5.14.02 version of RobotStudio ScreenMaker.Thanks0 -
where can i download 5.14.2?Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hello Klaus,The RobotStudio 5.14.02 is scheduled to be released and made available on download site during mid october.Thanks0 -
Hi, KlausI get the same error like you. Can you tell me how to use an application variable with same value . Pls give me the C# code, i am very urgent for it.Thank you in advance!0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
