IRBP B Positioner Calibration Frame Changed?
When comparing an old IRBP library of a B positioner to a new one, the calibration frame for the platter axis has turned -90deg about z.
Was this an intentional change or a mistake?
  • Hi,
    The decision was taken in the development team.
    The base frame orientation should now be more logic compare to other positioners like: L,K,R,D.
    BR / Henrik
    Kga Offline Center www.kgaofflinecenter.se
    Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac
  • Is it possible to change it back, so we can use it on the old stations ?
    Thomas G Andersen
    DanRob A/S
  • Was this change reverted?  Using the latest RobotStudio gives a B positioner with the frame in the original orientation (x pointing towards robot).
