Wrong configuration while linear moving
i have found a big problem in RS 5.14.01 SP1 when i use linear moving.
In some special positions you can set the config whith the correct values, but if you linear move a little bit, the config becomes wrong.  Please have a look to my two screenshots.
Any suggestions ?
Thanks for help.
Klaus
Config is OK:
Config is wrong:
Klaus Vogel
Kühne+Vogel Sondermaschinen GmbH
  • Hi Klaus,
    I can not reproduce your problem.
    Have you moved the Task Frame or Base Frame for the system?
    ABB Robotics
  • Hello Anders,
    yes the base frame has moved and is not the world.
    The task frame is 0,0,0.
    Please have look at my screenshots.
    I think the problem is the axis 1 when its value should go more han -90A?.
    This behavior occurs on some other situations also on robot 2.
    I have not so much time to investigate all the positions with this problem
    Please help me.
    Klaus Vogel
    Klaus Vogel
  • I have set up the same configuration as you, but can still not reproduce your problem. But if you mail me (anders.spaak@se.abb.com) a Pack & Go of the station you have problem with, I will try to reproduce it in that station and report it as a bug.
    ABB Robotics
  • Hi Anders,
    thank you for your support Smile
    I have reduced the station and have it attached here.
    I will also send it to you by e-mail.
    Please have a look at my station and give reponse a.s.a.p.
    Thank you very much
    Klaus Vogel
    Klaus Vogel
  • Hi Klaus,
    I have now tested with your Pack&Go, but I can still not reproduce your problem. The robots jogs correct with linear freehand for me.
    The only difference compared with your system is that I have tested with RobotWare 5.13 and 5.14.01 instead of RW 5.09 that you use. So maybe you should test to unpack your Pack&Go with RobotWare 5.14.01 and see if that helps.
    ABB Robotics
  • Hi Anders,
    thank you very much for your help.
    Yes you are right. - If i use 5.14.01 the problem is gone.
    There are much less configuration that i have seen before.
    The two wrong configs are not longer shown when a chose the config in dialog.
    So i think i will use the new RW 5.14.01, but the problem with 5.09 exists Wink
    Thanks a lot.ClapClapClap
    Klaus Vogel
  • Good to here that it works in RW 5.14.01. The problem is probably caused by a bug in RW 5.09, which is fixed in newer RW versions.
    So the solution is to not use RW 5.09 Wink
    ABB Robotics
  • Ok - I understand.
    How can i "easily" change the RW in my station to RW 5.14 ?
    Thank you for your support Smile
    Klaus Vogel
  • Make a Pack&Go of the station. Unpack the station, and in the Wizard select RW 5.14.01.
    ABB Robotics
  • OK. Thanks. That looks very easy.
    Thank you very much for your support.
    Klaus Vogel
