SM Enhancement: Events Panel
Tedenljung
in UpFeed
Open the "Events Panel" (Right-click on a screen a select "Event Manager"
Then select the event you want to edit and click on define, it is also possible to dubble-click on a event to edit it).
This window can be enhanced to be easier to use.
* Make window resizeble to make it easier to see whole description of the actions.
* Make it possible to dubble-click on the action you want to edit, instead of the tiny button in the end.
Tedenljung2011-10-06 15:59:49
Hello Daniel,Thank you very much for this valuable feedback. We will bring this up for discussion.Thanks again!Best regards,
Anders Jahnberg
ABB Robotics0
