reading e-stop signal
Hi All,
I've got a quick question which i'm hoping you knowledgable people may be able to help with.
I need to send a signal to a PLC whenever any e-stop has been triggered (ES, AS, GS).
The signal will be used to open a door which is controlled via a PLC.
  • Hi,
    For ES you can use the "System Output" signal "Emergency Stop".
    In the "System Parameters Reference Manual" (which you will find under the help button in RobotStudio) go to Topic I/O - Type System Output - Status values - Emergency Stop, for more information.
    ABB Robotics
  • Thank you very much for that.
    I've got that bit working now.
    Another question, is there a way to run a rapid code if an e-stop has been triggered e.g.
    when estop is triggered, run rapid code to set some flags?
    Many thanks
  • Hi
    You could create a event routine that will be executed with the event QSTOP and check in there if the emergency system output is set.
    You could also do a crossconnection with the ermergency system output in the EIO.cfg parameter.
    You could also use multitasking to check the ermergency system output.
    Best regards
    Marcel
  • Thanks everyone,
    I ended up using the QSTOP with an event routine. Works like a charm.
    Thanks again.
