Trouble using RelTool and Offs
Kat6987
I am new to RobotStudio and trying to use the RelTool or Offs function in the Move tool. I keep getting an error that the configuration is not verified, but AutoConfiguration doesn't work and I can't set the configuration manually because nothing comes up in the window. Any idea what I'm doing wrong? I'm using 5.14.01
Thanks!
Hi <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
In RobotStudio you can modify and do the configuration on real position but not on a robtarget function like RelTool or Offs. So you need to have a real robtarget separately. We call that a teach-routine. But if you then come with the offset to an other quadrant (see manual: confdata) in axis 1 or 4 or 6 it will not work. Then you have to switch off the configuration with ConfLOff; and ConfJOff; But don?_Tt forget to switch on again if not needed any more.
Best regards
Marcel
That did it. Thank you!0
- 367 IRC5
- 858 RAPID Programming
