call large number of robtargets
Dear Community,
I am dealing with a very large number robtargets in many paths. I want to modify all of them. I changed the declaration from CONST to PERS as I need the modifications (e.g. point_10.trans.x:=point_10.trans.x + 5.32) to be permanent in the code. But how can I call all those robtargets (point_10 ... point_10000) of a path with a single for-loop? Should be something like
var num number:=20
for number ...
point_"+number+".
number:=number+10
endfor
Thanks a lot.
  • Hi,
    You need to use something like the below to be able use a variable with a Robtarget name.
    VAR Robtarget TempRobtarget;
    PERS Robtarget Point10;
    PERS Robtarget Point20;
    PROC PosChange()
       FOR i FROM 10 to 20 STEP 10 DO
          GetDataVal "Point"+ValToStr(i), TempRobTarget;
          TempRobTarget.trans.x:= TempRobTarget.trans.x+20;
          SetDataVal"Point"+ValToStr(i), TempRobTarget;
       ENDFOR
    Hope this helps
    Regards
    Graeme
    graemepaulin2011-10-19 21:40:52
  • Dear Graeme,
    great answer. Thanks a lot.
    Regards
    Tobias
