Error running simulation
I'm working on a project with some SC. The stations has not been changed for the last week.
I'm only working with the rapid code but now i get this error when i try to test my rapid code.
I have upgrade to 5.14.02
I have 8 seperate tools with SC attacher and line sensors i have used the last 2 weeks without any problem before now.
I'm stocked and can't test my program Cry
Error message:::::
See the end
of this message for details on invoking <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
J
ust-in-time
(JIT) debugging instead of this dialog box.
Exception Text **************
System.NotSupportedException:
Not supported on mechanism links
   at
ABB.Robotics.RobotStudio.Stations.GraphicComponent.<get_Transform>b__1(Matrix4
m)
   at
ABB.Robotics.RobotStudio.Stations.Transform.InternalSetMatrix(Matrix4& mat)
   at
RobotStudio.API.Internal.AttachmentHelper.UpdateChildTransform(ProjectObject
parent, ProjectObject child, Matrix4 offset)
   at
RobotStudio.API.Internal.AttachmentHelper.UpdateAttachment(Attachment att,
ProjectObject obj)
   at
RobotStudio.API.Internal.AttachmentHelper.OnTransformChanged(ProjectObject obj)
   at ABB.Robotics.RobotStudio.Stations.GraphicComponent.<get_Transform>b__1(Matrix4
m)
   at
   at
   at
ProjectObject obj)
   at
   at
RobotStudio.API.Internal.PartMechanismLink.SetLinkTransform(Matrix4 mat)
   at
ABB.Robotics.RobotStudio.Stations.Mechanism.SetJointValuesInternal(Double[]
jointValues, Double timeStamp)
   at
RobotStudio.Services.Controller.VcSimHelper.Tick()
   at
RobotStudio.Services.Controller.VcSimHelper._timer_Elapsed(Object sender,
ElapsedEventArgs e)
PLZ help me
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi,
    I guess you have saved the station as a Pack & Go as a backup. What happends if you unpack that and tries?
    ABB Robotics
  • Hi Anders.
    I had a backup on my server from the 27th that i downloaded last night and restored my backup in my VC soo I was up running at 4 o'clock this morning.
    I still have the bad station if your RD want's to look into it.
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Hi Klaus,
    Good that you are up and running again Smile
    Yes, we would like to have the bad station. You can mail it to me (anders.spaak@se.abb.com).
    ABB Robotics
  • Hi Anders.
    I made a pack&go but after trying to unpack the error is gone soo trobleshoting is to make a pack&go.
    Problem is solved in a change way LOL
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
