Object reference not set to instance of an object
Hi All,
I gets an error mentioned below.
"Object reference not set to an instance of an object"
Pls let me know what could be the possible reason for this error.
Regards,
JJ
This error is fairly common for me since I have upgraded to 5.14.
It has always been caused by an instruction dropping it's robtarget. The only solution I have found is to go into the paths and targets and delete the offending instruction, then recreate it. When attempting to select the instruction to delete, RS will ask if you want to quit or continue, keep hitting continue until the instruction is selected and then delete.
Hi,but how do i find the offending instruction?? is it something i have to delete all my paths and targets and reload or recreate it???Regards,Jipin Jose0
Hi,The first thing I recommend you to do is to upgrade to RS 5.14.02.When we continuously corrects reported problems, it is a good chance that this problem is solved in the latest release.Best regards,
ABB Robotics0
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 10 AppStudio
- 105 Collaborative Robots
