no units to activate
I have created a new station that is shown below.  When I open a new path in AcrWeld and try to create an action instruction/ActUnit,  I don't get the STN1, STN2,INTERCH choices.  The choice I get are IRB, ROB_1, and ROB_ID.  How do I get the stations to appear so I can program the path?  Thanks.
  • Do you have the external positioner in your simulation ? I was comparing yours with my station and I found out that you are missing a folder under T_ROB1 which for me is AR_##### and I have my STN1 under that ...
    After importing your robot and external positioner to the empty system you should create a system from layout, have you done that ?
    Shahab
    Sky is the limit ...
  • The create station from layout does not seem to work.  No versions or RobotWare show in the imageselection box.
  • I see that ... mine has it ... Try to close the sataiton and do it again if you can ... follow the steps :
    • Start an empty station
    • RobotStudio -> Home -> Import Library -> Browse for Library
    • Choose your prefered robot from this path :
      "C:Program Files (x86)ABB Industrial ITRobotics ITRobotStudio 5.14ABB LibraryRobots"
      OBS : yours might be different if you have chosen another installation path.
    • Choose your positioner (e.g. IRB750K_D1000-L1600_M2001_REV1) from the following path :
      "C:Program Files (x86)ABB Industrial ITRobotics ITRobotStudio 5.14ABB LibraryPositioners"
    • After it clikc on Robot Systems and then From Layout
    If this doesn't work then I guess you miss something in your RS.
    Shahab
  • I get this error if I attempt to create a station by layout.
  • Did you try this only one time or at leat couple of times ? If you have tried this more than once and it gives you the same error each time, then I guess there is something wrong with ur installation.
    Try to uninstall (all robotstudio folders) and re-install again. But I dunno more than that ...
    Shahab
  • I un-installed everything and re-installed.  I get to the last step of creating a station from layout and this message comes up.
  • Please contact your local ABB office for support with this problem.
    ABB Robotics
