Changing system.
Hey,
I've got this robotstudio project in our course, where i have 3 robots in my system. Layout is done and coding is going pretty well, but I now need to change one robot to other model. I'm pretty lost about how to do it, because the system is allready setup and I cant find a decent way to do it.
Do I need to setup up system again from new layout where the new robot model is or can robot be changed in a system that is already build up?
I'm just afraid I need to write majority of the code again etc..
-once i thought i was wrong but i was mistaken-
  • Hi,
    I recommend you to save the programs , create a new system which you add to your station and then load your program into the new system.
    It is possible to modify the existing system with System Builder but as an I-start would be required all programs would be removed anyway.
    Anders Jahnberg
    ABB Robotics
  • Hey,
    I did like you recommended and it worked out just fine!
    Thank you AndersJ for help :)
