problem with Mediapool
I have Robotwares installed in my computer, but i'm not able to select it while creating system in system builder nor system from Layout.I have tried re-installing Robotstudio and Robotwares many times , but still the same problem continues. it is giving me an error."invalid directory"
Pls help me to solve this issue.
Regards,
Jipin
Someone pls reply... i have to work in RobotStudio!!!!!!!!0
HiDid you install any RobotWare to your local hard drive?I have there a RobotWare like:C:Program FilesABB Industrial ITRobotics ITMediapoolRobotWare_5.14.2031If you have that, you should also be able to see a robotware version in the first window when you create a new controller system.Best regardsMarcel0
Hi,You can see in the attached picture that i have shown all the robotwares installed.i have it from Robotware 5.10 to 5.14.Regards,Jipin Jose0
Waiting for replies.Regards,Jipin0
Hi,It appears from your create system from layout screen shot (in the original post) that the media pool (RobotWare) is not in the default location?Did you try to browse to where the media pool is located?RegardsGraeme0
Hi,Yes i have done that also. but still it shows invalid directory..Regards,Jipin0
Hello Jipin,
Please re-install MSXML 4 SP3.
1. First shut down RS.
2. Download and install from here:http://www.microsoft.com/download/en/details.aspx?id=15697
3. Then start RS and try again.
Hopefully this will solve the problem.
Anders Jahnberg
Hi Anders,Thanks alot. Its working fine now.Regards,Jipin Jose0
- 336 IRC5
- 67 OmniCore
- 830 RAPID Programming
- 13 AppStudio
