program joint target
Is it posible to teach a joint target in robotstudio?. When I press teach target a robtarget is created, but for some things I need to teach a joint target and I don't know how to do it without manually input the values (which is a nightmare)
thank you
thank you
Change to the 'MoveAbsJ' template in the RobotStudio status bar at the bottom of the screen before teaching your target, see picture below.
ABB1 -
Thank you!!!
Fro multiteach I can change to MoveExtJ in status bar but its sort of mixed system some external axes, some robots?
- 367 IRC5
- 858 RAPID Programming
