Fp interface on rw 5.14
Klaus
How Can i write a Fp interface to rw 5.14?
As i Can se i must use rab 5.14 but Then i must use vs 2010. Another tropic tells that it Can not use compact frameworks in vs2010 . Will a rab 5.13 run under rw 5.14? I have very bad expeeience with differentiere rab and rw versions on the same controller
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,To develop a FlexPendant interface for RobotWare 5.14, you should use VisualStudio 2008 and FlexPendant SDK 5.14.It is correct that 2010 does not support Compact Framework.0
