exception during starting Station
have a problem with one station: a second after the message that the station was successfully loaded, an exception emerges "value cannot be null. Parameter name: source".
does anybody know about this problem and eventually has a solution?
the station is using RobotWare5.11.1033 - all my other stations base on different RWs and are working just fine - so this may be a problem with this RW?
am using RS 5.14.4241.204
thanks
