I/Ocross connection from VC to SC
sturner
How do you get a cross connection between a VC and a Smart component?
I.E from doGripper in the VC to diGrip in the SC
Many thanks
You can create cross connetions using Station Logic.
Thanks... simple when you know !0
Very useful thanks, but I need send signal between the VC and smartcomponent in both direction.
Now i canA't connect an output of smart component(like executed) to and a my signals in the VC, only let me connect to an Local signal like AS1, EN1...... I tried to crate a new unit in local bus , but i dosenA't work.
Can you help me!!
Thanks in advance
You need to define your own I/O-signals in the controller. Create a new unit of the type "Virtual" that you connect to the bus "Virtual1". On this unit you can define your signals. For more information take a look in the System Parameters Reference manual.Best regards,
ABB Robotics0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
