Question
comandos
Greetings allA?
I am new to robot ware 5.12.04 and I have a little problem I wish to create a path along the edge's of a gas tank (witch twists and is very uneven), i tried to use "create target on edge" but im finding that some of my points are in mid air and not were they were suppose to be, am I using it wrong or do I have to manually correct every missed point?A?
When searching the forums I came across a command "path from curve" is this command still in the program or is there an alternative?
Any help would be much appreciatedA?
Ole
Hi Ole,I recommend that you install the latest version of RobotStudio (5.14.02.01) and use the function "AutoPath" which is the successor to "Path from Curve".Best regards,
ABB Robotics0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
