program displacement on IRC5
spiney
Im using a IRB2400L and am welding with a frame jig, now I have replicated frame jig 3 times. I have a program for my first jig, how do I do a program displacement on IRC5 for the other jigs without rewriting the whole program.Any help would be very appreciated.
You can enable a program displacement by using PDispSet *; command.
Such as:
[code]VAR pose FrameJig1:=[x,y,z][q1,q2,q3,q4]
VAR pose FrameJig2:=[x,y,z][q1,q2,q3,q4]
VAR pose FrameJig3:=[x,y,z][q1,q2,q3,q4]
!//Decide which FrameJig you are using
PDispSet FrameJig1;
!//PDispSet activates a frame which is relative to the object coordinate system
PROC MovementRoutine()
!//PDispOff deactivates any displacement frames
PDispOff;
[/code]
Only one program displacement can be used at a time. In your case, all you need to do is define the FrameJig1,...,n, using the pose datatype. Then just call the corresponding FrameJig for your operation.
Excellent, Thank you very much that's exactly what I was trying to do.0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
