a delay time before robot moving
weisheng
hello, everyone
recently, I got a problem, it's a big trouble for me.
The robot always run repeat at one position except for changed the offset from pc-sdk.
But when i changed the offset ,there is a delay time about 0.5s before robot moving.
Dose anyone find this problem ?
how are you changing the offset? RAPID Data domain or Messaging domain or ??? I found recently that removing Messaging from my application significantly improved performance.0
I use the RAPID Data domain.Excuse me , what do you mean about removing Messaging?Could you tell me how you change the offset?thanks0
has anyone figured this out?
I also get a 0,5 s delay.0
