Failed to creat system from back up
I want to creat system from back up ,but failed.
The prompt is as follows:
Have but few friends, though many acquaintances.
  • Jorge
    Jorge ✭✭
    Hi, the message says every thing. You are trying to make a system from Backup, but this backups uses a addtional Option, that you don't have in your mediapool folder (Mediapool forlder is the folder where RS store the RobotWare and addtional options).
    You must get a copy of the additional option. Usefull you can find it on the robot where you get the Backup. Search for a folder into de HD0a called 3HNA01783-001, and get a copy of folder.
    Then import it using "Import options, on Online tab.
    /Jorge
    Jorge Turiel
  • The problem is solved with your help,very grateful!
    I work as a paint robot engineer in an auto company since I graduate from university last year. I found  the work is meaningful  but hard to learn at the same time.After few months,I have learned something simple about maintence . But what I really want to learn is about programming,reference materials are limited,  only robot manual is available.
    Thanks to the internet,I found the useful information.
    Robot Studio,which I think will be helpful,but I do not know how to use it , free tutorials are very useful but too little to help.
    SO I wonder if I could get any help from you.
    Thank you very much!
