How do I resolve this error!! [Painting PowerPac]
in PowerPacs
On all the other robots i am able to insert an event in a path but this robot keeps giving me this error and I am not sure what is causing it.
Hello,Do you get this error when you select any Particular PaintL instruction or is it for all the instructions in the system ?Can you send a P&Gbest regardssudarshan0
I get this error on ALL. I do not understand what object it wants me to set an instance too, or how to set it?0
Hi, sorry forlate answer but Ihave been on leave for a while.Can you expand the error box so we can see the whole message?It seems tobe related to the Add Event task in PaintWare.Do you get the message when savin the Rapid code or at execution time?Tormod Henne
Senior Engineer0 -
i think tormod is guessing the right may be the reasons would be tobe related add event task in PaintWare you should check it out ..
- 345 IRC5
- 71 OmniCore
- 843 RAPID Programming
- 19 AppStudio
