SystemStatus RunchOk S4C+
to check in RAPID if safety doors are OK i can create an virtual signal in IRC5 like this:
# SYSSIG_OUT:
 -Status "RunchOk" -Signal "soRunChOK"
If something similar in S4C+?
I have to know in S4-RAPID if AS1 and AS2 ok or not (not for safety reasons only to make teaching more easy without trying enable external device while doors are open!)
thanks  dust2
  • This is copied from a eio.cfg for S4C+
    SYSSIG_OUT:
          -Status "RunchOk" -Signal "doSimRunchOkIRB"
    Otherwise you can check directly on AS1 and AS2. They are accesible as I/O.
  • Thanks jyrgen
    This is working basicly, but in manuel mode with closed doors ( AS1 AND AS2) doSimRunchOKIRB is also FALSE as in manual mode with open doors!?
    IF (TestDI (AS1) OR TestDI (AS2)) RETURN;
    This return error unknown object AS1/AS2!
     My problem is, that production and teaching new workpiece is all in manual mode. To distinguish between it, i want to have a look at AS1 and AS2!!?
    dust2
  • Dust2,
    You can't get direct access to AS1 and AS2, but if you make an eio cross you can use them!
    EIO_CROSS:
          -Res "diSimAS1" -Act1 "AS1"
          -Res "diSimAS2" -Act1 "AS2"
    Jyrgen
