Help?
Dear All,
I've connecting 1 encoder to 2 outputs. 1 for robot and 1 for PLC. As long as I know, i think there's no problem with it. But, can somebody share with me, is it secure or no ( to long periode usage)?
The things that I worry is about the current. With paralleling output, the current will be decrease. Or there's something else that I must notice?
Thank you very much
BR,
  • Dear Majid
            Yes, you're alright, Encoder which connect to ABB must PNP and this Encoder type need 24VDC. Here are my experiences using Encoder on ABB Robot :
    1. Connecting 1 Encoder to 1 Robot and 1 PLC (NPN):
        No problem with some conditions :
        - I choose a low voltage Encoder (5 VDC)
        - I use converter (PNP to NPN and also 5VDC to 24VDC), It is caused my PLC need 24VDC and NPN
    2. Connecting 1 Encoder to 2 Robots :
        Until today I have no problem both using 5VDC Encoder-PNP and 24VDC-PNP for Conveyor Tracking purpose.
    I hope It will help
    BR
