ACIS (.SAT) Import Geometry Not Visible
I am attempting to import SolidWorks assemblies and parts into RobotStudio 4. I save the files as ACIS (or .SAT) files from SolidWorks, and then select "File>Import>Geometry" in RobotStudio. The files seem to import fine (at least no errors are shown) and the objects appear in the Object Tree. However, I cannot see them in the work space, even though "Visible" is clearly selected.
Is there a specific version of ACIS that RobotStudio 4 requires? Is there some other special requirement I must fulfill when I export the file from SolidWorks? Is there perhaps an option in RobotStudio that I have overlooked?
Thanks for your input.
I found a solution for those experiencing the same problem. Under SolidWorks export options, when selecting the version, use ACIS version 7. This version is compatible with RS4.0
- 364 IRC5
- 83 OmniCore
