S4 Backup Error
While trying to do a backup on a S4 controller, Error 10071 occurs.
The S4 manual states:   10071: Backup error
Error During the backup
Of %!%!%s
%s
Check:
%s
Can anyone explain this?
Warm start and deleting uneeded files from controller did nothing for me.  Looking  at recent backups on controller the folders are there but they at empty.
  • Do you store at the harddisk?
  • Correct.
    During the backup routine, when asked for a  file location if you use the default location or create your own i am told the folder is not empty.
  • Yeah, problem sounds familiar. I've been struggling through this also. Workaround i found is to save to a floppy, and then copy it to the harddrive. That worked.
  • I am familiar with this error also, we see this error when saving to a flashdrive that has been formatted incorrectly or has a filetype that the robot doesn't like. We format our flashdrives into 100 floppy disk blocks and save a Microsoft Word file to the first block containing all robot cell information. If we try to back up to disk block 1 we get the same error. Hopefully this helps..
    -matt
